Is it possible? The TSRM says you have to, but is there a way to just "block off" the coolant passages to the turbo instead of having to drain the whole radiator before removing the coolant lines?
johnathan1 said:I've always pulled the turbo without draining the system...you only lose about a cup of fluid...not a big deal really.
emiliorescigno said:By "lose a cup of fluid" do you mean just letting it spill out of the turbo coolant hoses onto the ground until it stops?
lagged said:geez use your heads people.
first, remove the water lines FIRST, block off with two bolts.
be sure to do this BEFORE removing the ic pipes and most importantly, BEFORE you remove any oil lines. the coolant will spurt out and the chance of spilling some into the oil drain is high.
annoyingrob said:Is is really THAT hard for you guys to drain the damn coolant? Unscrew the drain plug, and leave it for a few minutes.
I just don't like spilling shit all over my engine bay. Maybe I'm just used to cars with hard coolant lines, but it's pretty hard to plug them.Sawbladz said:Why go to the extra effort and expense when it takes 2 seconds to just plug the line?
