removal of shocks
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
whats the easiest way to remove the from shoscks..because i bought tociko ilumians and springs..but i can't get the from shocks off because the bolt is on so tight...another question is how much would it be to bring it to a shop and let them do it?
Suprawannabe
meh... im lazy
Oct 27, 2005
122
Denver, CO
staticpat said:
Be careful, I've heard stories (urban legend?) of people unspringing a shock and puncturing a lung.
If someone takes a loaded spring off a strut without a spring compressor and has it pointed at there chest... well lets just say thats learning the hard way.
Its very simple to change your suspension. If you look at the link it shows that you have to take off the uppercontol arm bolt (kind of a pita on passenger side) and strut bolt for the front. For the rear all I did was take off the rear strut bolt and that was it. The suspension on mine though was not stock so I don’t know if that will work as easy for you as it did for me.
Then use a spring compressor to put your springs on the tokicos( if you need it) and install the same way you took the old ones out backwards.
