I hope this is in the right section...
Also, I have searched and searched on this subject.
My setup: DM 57trim, Lex/560's, supporting mods, hard pipes, greddy type rz BOV.
Problem: If i recirculate, it surges. I have a screw in fitting for the bov that gives me a 19mm nipple. This is run into a 90 degree coupler and into the hole in the accordion hose. No matter how loose I set the BOV it will always surge. It is almost like that small hole in the accordion just cannot flow enough air to fully release the pressure.
If I vent to the atmosphere, it works perfectly. Put on the recirc fitting and it surges.
I have gone through all the vacuum lines and made sure they weren't pinched or broken, tried different vacuum sources, disassembled the BOV and verified operation.
Before the 57 trim upgrade it worked perfectly recirculated. My next idea is to get one of the metal accordion pipes from ebay, enlarge the recirc hole and use a bigger fitting on the bov and a large hose to recirc.
Does anyone else have any ideas or thoughts? Im getting sick of venting to the atmo and the whistle is starting to get anoying.
