Rebuild
boostedKids
11
northern nj
ok, im rebuilding a motor i have, its got 98K on the clock.
it spun a bearing on number 5.
its already apart completely.
I was going to get the crank cut, polishing, everything cleaned, block machined, valve job, new bearings, possibly new pistons from toyota and at least one new rod.
i also planned on the following:
EGR blockoff(how, and what parts needed?)
MHG with ARP studs (what torque?)
Charcoal canister already gone
new plugs and wires
apex'i intake
all new hoses
the bosch BOV
rad. cap
optima red top
im also getting rid of TEMS (i dont have the factory TEMS struts anymore)
i need tires, brakes, pads, lines (suggestions)
and in the near future, BIC DDP, NUR Spec-R, test pipe, FATT DC, and i want new clear headlamps and bulbs and i need foglights.
finally, im getting new fluids ALL AROUND (again, good suggestions)
so its a little more than a rebuild, its a basis for a project i just started.
i know it sounds like a lot :aigo: :aigo:
but any help will be most appreciated.
thanks guys
-justin
shaeff
Kurt is FTMFW x2!!!!
11
Around
new plugs and wires
apex'i intake
all new hoses
the bosch BOV
rad. cap
optima red top
thanks guys
-justin
searching would yeild most of your answers for you, however:
just order a set of EGR blockoff plates from JBLMKIII, (john lunsford) hes in our vendors section here.
get a Cometic MHG, and ARP studs, and torque it to 90ft lbs.
kumho tires are relatively cheap, so you can burn through them, and have decent traction for summer driving. i used kumho ecsta supras.
i would get a wilwood kit, but its really costly. if you cant afford it, get stock brakes for now. all new pads, lines etc... or maybe those brembo slotted rotors i see on ebay every so often. i've heard of people liking those.
redline makes good fluids. so does royal purple. for motor oil i use mobile.
good luck!
-shaeff
