Rebuild/Change trim of stock 1jz twins
Prettyazznouka
75
NYC
Is it possible to upgrade the trim of the ct12's Is it really a cost effective alternative to going single? Basically make them be able to hold higher boost
lagged
1991 1JZ
new rochelle
search ebay. there are usually sets of 1jz twins rebuilt with steel turbines for ~1500 shipped to the US. seems like a good deal to me.
lagged
1991 1JZ
new rochelle
let me add, ~1500 shipped and NO core charge, warranty.
Tim
regular member
Oct 16, 2006
272
CA
its expensive, and you won't get huge gains out of the setup with out sacrificing spool, and then for the money you might as well go single!
Prettyazznouka
75
NYC
Yea I know 1299 is a real good deal.... My twins are fine, they dont smoke. Boosts well. i dont have a boost controller. And I was told not to get one cuz I will blow the turbos. I like how they spool up though. I wanna lay down 350-375. Might as well just bite the bullet and go single I guess. Cant upgrade the twins, ct20's dont work, whats left is ct26, nitrous, or single...
Prettyazznouka
75
NYC
But would running higher boost facilitate the demise of the twins? I just came in from running with my boy in a 06 gs430. gotta good jump on him in 1st had him in second a bit once i hit third it dies..... needa go front mount!
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
You're not going to gain much by replacing the intercooler. You will gain a lot more by upgrading cams first (it's cheaper too)
Just ask my buddy. Both of our cars were stock JZA70s, both had intake and exhaust. His had intercooler, mine had cams. Mine ran 4 tenths faster in the 1/4
us
definitely dont waste your money upgrading the twins. for the same cost you can go single. and even if you aren't going for big power, a single will be more reliable. definitely dont put on a ct26, your car will never be fast. and dont put on nitrous unless you are using it solely to spool a mammoth turbo, otherwise your car will only be fast when you're spraying. just go single. its the most logical alternative to stock.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
If spool is so important you could always get a GT30 high A/R equivalent.. you'll never know what lag is. Many 1J drivers use them in aussieland.. Personally, I believe that the power potential is a little lower than what I want, but cant argue with the power delivery.
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
just wondering about the comparison between the ct26 and twins, because i am looking to start my 1j swap within the next few months, and money is an issue, and i would like to keep and use my almost brand new titan dp..
so what do you guys think, stock twins or stock ct26 which will eventually be upgraded?
