Rearend Axle/Diff specs?
PorterzSupra
703
Hebron CT
Does the Supra use the same axle splins as other toyotas? I am looking into gettin a detrioit locker or some time of ratcheting spool to lock the rearend. Anyone know the # of teeth or if its the same as other Toyota rear end axles?
IHI-RHC7
"The Boss"
Oregon
The axle is not the problem.
The inner race of supra bearings does not fit onto toyota truck difs. So far I don't know of anyone who has found a "hybrid" bearing that will mate the truck carriers to the supra case.
PorterzSupra
703
Hebron CT
so is the axle teeth the same as the other toyotas, bear with me I might be on to somethin, I am not tryin to mate the truck carriers to my rearend, the spool would replace the carrier if the teeth are the same mesh
IHI-RHC7
"The Boss"
Oregon
The spool is the carrier... unless it's a mini spool, but I can't find a mini spool for the 8" truck diff.
