aadsen said:
			I get that leak too when i open the hatch. Does it come out from behind the panel of the hatch when its open. Cuz thats where mine is. I just haven't found the problem yet.
It comes in from where the glass meets the hatch on the bottom, under the molding.  The molding can be removed, and you can use some glass adhesive.  Talk to someone at a body shop to get the same stuff they use.  Silicone will not last long, as it will shink and pull away.  BEEN  there, tried that!!
Also, if you reach way up towards the front, in each of the fender cavities (where the jack goes on the drivers side, for example), on the bottom you will feel a rubber plug.  I removed it to allow the water to stay drained off.  I did NOT have any water coming IN from those small 1/2" holes when TEST  driving thru the water-filled gutters.
Now thus areas stay dry. :icon_razz
