Rear diff oil change question? Pls Help!
MA70_452
South Wales
I am preparing to change the rear diff oil, i have bought the oil already, i would likt to ask your guys how to do it, like where is the drain plug, refill plug and what do i need to beware of?
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
jetjock said:
It is...except always, I mean always, remove the fill plug first ;)
omg yes, i remember someone telling me that and i was like wtf? Once you get under you'll understand...
HellsLegion said:
Get a pump to put the oil back in. It makes shit soooo much easier.
yep i got one and it took about 2 fills of the pump to get it back in. easy as pie.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
jetjock, you're back? and someone explain why you need to take the fill plug out first. is that to let air in as the oil is flowing out?
Tire Shredder
569
Oshawa
what oil did you buy?
make sure if it's regular 75w-90 gear oil that you put in some frictoin modifier or you'll burn up the LSD clutch packs.
