i pulled some text off of this site
http://www.brian894x4.com/Gearratiosanddiffs.html
Above is typcial earlier model Toyota VIN plate, located on the engine compartment fire wall. This one is from my brother's 1986 Toyota 4X2 truck. The
gear code is circled in white and is G662, indicating 3.07 gears and an 8" diff and 2 pinion open carrier, which is surprising considering that many 4x2
trucks came with 7.5" rear diffs. But some did come with 8" diffs. I measured his just to confirm it was an 8" carrier, and it was.
so seing as this is a gseries diff...
these gears should work in a mk3 supra rear endÉ
im using a getrag and the 3.07:1 suits it quite a bit better than the stock 3.73:1
how would i go about getting a part number for the 3.07:1 rear end gears, so i could just order over the counter at the toyota dealership.
thanks,
jeff
thanks,
jeff
