Rear bump stop options?
Mastapip
143
Ft. Worth Tx
This seemed like a good place to post this.
I'm going to be swapping out my springs soon (I have H&R's, going to switch to Eibachs), and I'm gonna replace some other worn out parts while doing it.
In the front I recently replaced the bump stops (KYB ones from O'reily's) and also swapped out the old busted spring hat insulators. Friend of mine told me that the same KYB ones i bought don't fit in the back.
When I replace the springs, I wanna replace the bump stops and insulators in the back as well.
Does anyone know of a bump stop (available at autozone or O'reily's) that fits in the back with little or no cutting? IIRC the Toyota ones are around $40 each.
Links or Part numbers would be great. Thanks!
Whatever you get make sure they're long enough to prevent the shock bottoming out internally, I lost a Koni that way using stock bumpstops that split.....
(ended up using some aftermarket Porsche ones that have a nice progressive accordian section in them)
