Ready for a new headgasket, questions
TargaMK3Turbo
Money pit thats worth it!
Jun 11, 2007
235
Lambertville, MI
Hey everyone!
So I just got my head back today, I was told the 0.006 was shaved off. The head was also flow tested and gone through.
Here is my problem(s):
The motor was replaced 4 years ago. 1800 miles ago is was freshly rebuilt by an owner who I cannot get ahold of.
I have no records of the head being shaved before.
I blew a bead gasket, when removing the head I could easily loosen the head bolt with a 3/8 drive wrench. My guess is the gasket blew due to improper torquing.
So, I'm buyin through 935 motorsports. I need to get a combo for ARP head studs, a headgasket kit, and a Cometic gasket.
What size gasket should I go with? It's a stock 7M and I plan on doin bolt on's, no major engine mods.
Thanks!
I have to order today so the sooner the replies, the better :icon_bigg
You can also talk to me on AIM BA94pgt
I'll be online till I get an answer, lol
dugums
Better, Faster, Stronger
Apr 10, 2007
699
Chicago, IL
TargaMK3Turbo said:
six-thousandth's
no, nothing was taken off the block, but it's flat and smooth. Thats why I'm going with a Cometic and not a MHG.
??? Cometic is a MHG
TargaMK3Turbo
Jun 11, 2007
235
Lambertville, MI
starscream5000 said:
How do you know the block is flat and smooth?? You need to edit the amount taken off the head in your first post, you're scarring people who are reading this.
lol, one 0 short, lol.
A dial indicator was used.
Also, the head was barely tightened down. Whoever rebuilt this thing only did the 1st step in torquing down the head. It didn't blow out the sides, a couple went from cylinder to cylinder. It wasn't bad at all.
TargaMK3Turbo
Jun 11, 2007
235
Lambertville, MI
A compressed stock HG is 1.37mm thick. .006" is 0.1524 mm. To keep the stock compression, all you have to do is the simple math ;).
Thank you
But thats not my problem. The engine was replaced about 4 years ago. Rebuilt about 1800 miles ago. I have no idea if any of the head was shaved then...
Do I go 0.1524mm or larger?
TargaMK3Turbo
Jun 11, 2007
235
Lambertville, MI
2.0mm should leave you safe ;). But it you really want to know, the stock thickness of the 7M head is 116mm from cam deck the head deck.
Thanks, I'd rather have a lil lower compression and be on the safe side then be too close and things start breaking.
Can I use a Cometic then? If not, what the very best gasket I can use for my application?
dugums
Apr 10, 2007
699
Chicago, IL
TargaMK3Turbo said:
I was told I can go with a Cometic being my head is shaved and block is not.. I'm confused now...
Cometic is a MHG that, by specification, requires a surface that is not quite as smooth as what other MHG's require.
This doesn't mean it is supposed to be used on an unprepared block. Prep work will still be required to achieve the recommended RA on the block for a Cometic HG.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
All you have to do is measure the thickness of the head to see if there was ever any material taken off of it besides what your mechanic took off.
The very best there is is open to discussion, but most would say the 2.0mm HKS stopper MHG, but you'd be wasting your money on it without pulling the block and taking it and the head back to be smoothed down to and RA of 20 or less...
TargaMK3Turbo
Jun 11, 2007
235
Lambertville, MI
Ok, so what gasket should I go with?
If I'm gonna do this, I wanna use the best stuff the 1st time.
ARP head studs
Headgasket kit
???? headgasket????
The block is staying how it is. I don't want to use a MHG if it's not going to be the best choise for what stage I'm at now.
startscream5000, do you wanna talk on AIM?
dugums
Apr 10, 2007
699
Chicago, IL
Get a Toyota head kit. It will have all of the top-end gaskets (including headgasket). Even valve seals, etc are included.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I'm at work, sorry.
If you don't want to pull the block, then my suggestion is to stay away from the MHG's as they will be prone to blowing without being absolutely sure the block is flat and smooth enough for your MHG brand's specific RA specs.
