re-wired knock sensor
Metal-Inc.
Vancouver
i re-wired my knock sensor last night and took it out for a spin this morning and the problem has gotten worse. uphill it almost stalls and sometimes does stall. on flat land i can barely touch the throttle without it making a sputtering noise, this KS thing is starting to frustrate me. i don't know what it could be, i reset the ECU and am not showing any codes.
Thanks
DaSuprawolf
Im SICK of N/A
Dec 29, 2005
456
ChicagoLand
your car isn't going to run that bad just from a knock sensor problem......
i had mine unplugged for like a month once. it ran fine just had no performance.
no codes?? check timing? vac. leak?
Metal-Inc.
Vancouver
i checked, i have no codes, how do i go about checking the timing? and i cant see any vacuum leaks that i am aware of but there happens to be no air filter on the end of the VTV.
Thanks
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
check timing........... jumper e1 to t1 plug in timing gun and point at harmonic balancer. should be at 10* stock timing. you should see a notch near the block and then numbers on the balancer itself. it should be at 10*
