RC 750cc & 720cc injectors. (750 only available?) / (VPC 720cc question)
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Part 1:
I was reading up on injectors, specifically RC "720cc" injectors that Genna ran in the red car... but all I see on HFP for RC's are 750cc.
I need a set of injectors to support 700hp MAX, with usual workload to do 600 daily.
Part 2:
I'm running a VPC with a 550 chip, but I know several of you are using the same.
My question is: How is drivability on 720+cc injectors with the VPC / AFC combo?
Thanks.
-Brent
PS. I'm dynoing this saturday, so I'll post results... good or bad.
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
MK3Brent;944630 said:
Part 1:
Part 2:
Thanks.
-Brent
It will work.....I used Vpc emanage combo, but blackdevilsupra used Vpc afc and 720 injectors or was it 750 injectors.lol
KevinM
Knowledge driven
Seattle, WA
I did a VPC/SAFC2 with 72lb/hr inj for a long time in my supra and never had a problem with day to day driving. The mileage wasn't the most impressive around town though....
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Well I don't drive the car more than once a week, if that... and wanted to have some head room to hit 600hp w/o running out of injector.
Looks like 680's will be going in... should make tuning a little easier compared to 720-750's at the moment.
I think I'll run a dual feed to the rail first though.
QWIKSTRIKE
Apr 3, 2005
1,172
Thats what I did.....Took a spare fuel rail to the machine shop and had him make a hole dead center and tap it the same size as the front feeder. I used the feul damper as a feed the center as the return and get fuel feeding from both ends equally. CSI still in place also.;)
