Radiator questions?
Ymh
120
Oklahoma
I traded for a racing radiator but there are no lines out on the bottom of the radiator. on the stok one there are two lines on it 1 for the overflow tank and the other i really dont kno where it leads to beacause it has been capped off. So my questions are do i need the other outlet (which is the one closer to the passager side) and do i need a return line from the overflow tank to the bottom of the radiator?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Ummm...the lines out the bottom on a stock radiator are for an auto tranny cooler. The overflow line is located on the cap neck.
Ymh
120
Oklahoma
its a five speed and there is a line that come fomr the radiator to the overflow to the bottom of the radiator, if so then the person b4 me is stupid
jdub
Feb 10, 2006
10,730
Valley of the Sun
I assume you have not had the car long...the stupidly of "some" Mk III owners is well documented.
As you can see in this pic...the overflow hose connects to a fitting on the rad cap neck. It also sounds like you have a radiator for an auto in your car...perhaps a tranny swap to manual was done in the past?
Ymh
120
Oklahoma
i had it like a year but havin the car running is a different story. Under the hood was trashed and i hav a ton of plugs am not sure where they go. I'll take pics of the radiator today to show whats goin on.
Ymh
120
Oklahoma
You hav an overflow tank?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Of course...that's where the hose leads to in the pic. It's a stock tank in the stock location...just doesn't show in the pic ;)
Ymh
120
Oklahoma
The overflow hoses goes in here from the overflow tank. is this right?
and this side is capped off
jdub
Feb 10, 2006
10,730
Valley of the Sun
No...that is not correct ;)
What about the fitting on the rad cap neck...is it capped off too?
Ymh
120
Oklahoma
it goes off the filler cap to the overflow tank then from there
This car is a piece but i only payed $200 for it.
the fans has like on 2 and 1/2 blades on it and the shroud is in 2 parts, to name some of there other probs
Ymh
120
Oklahoma
Nick M said:
So is that bailing wire or coat hanger you are using?
no thats how i got the car. i took that off andall the APC stickers. but i know takin off APC stickers made me lose 30hp
ya if a 5speed and my new radiator doesnt hav does outlet, so where does this other overlow hose connect to?
