rad removal with hydro fan
cbutler
218
Regina, SK
Can someone tell me if I need to drain all the fluid out of the hydrofan if I need to remove my radiator? If so where's the best place to drain from?
Thanks,
seoul4korea
620
San Diego, CA
www.supraforums.com
Either that or unbolt it and lift it out with the lines attached and move it off of the side. It's not too hard and if you don't have the new lines i'd look into the condition of them if you decide to drain the lines..... Might as well change them out while it's off.... unless they're still good.
cbutler
218
Regina, SK
thanks guys, I drained it and removed. The lines are starting to feel pretty brittle so that might be a good idea. I was changing cams today but my crank pulley bolt is being a bitch so that's my next problem. I'll have to try and find someone with a good impact I guess.
Intrnlstorm
One Jizzle
Aug 27, 2006
123
Schenectady, NY
Just do a search for ways to remove crank pulley. My impact did nothing to my bolt. Awesome impact gun too. I used the "long breaker pole, crank engine method" worked great!!!
Joel
