R154 weird noise
shipkiller
398
Quebec
my r154 make this sound: http://www.youtube.com/watch?v=_LtHs0Zydew
when the transmission spin
if I put it in neutral and I press the clutch, it stop, but as soon as the inputshaft spin, it make this noise (but much worse).
I was coming back from work, everything was fine then it started doing this at a red light, I can actually feel a vibration (according to the noise) in the shifter lever. and I sense weird vibration in the clutch pedal when I release it.
My clutch started slipping like 2 weeks ago, I'll replace it with a brand new toyota oem PP,disk and bearing kit.
what do you think it might be?
toyotanos
What will we break today?
2,844
Coon Rapids, MN
Might be a throwout bearing going out or soething inside the tranmission. My money's on the TO bearing.
I say put the new clutch kit in and buy a new throwout bearing, plus all of the washers attached to it. *Be very careful how the washer are reinstalled, its very easy to mix that order/direction up!
shipkiller
398
Quebec
I'm afraid to drive at all, but I'll try to get into 4th gear to see if it goes away
but my exhaust system is very loud, I won't really hear it, only feel it through the gear knob and the clutch pedal
