r154 mount ?/help - the car side
steve_mk3
middletown, NJ
Hoping you can help or point me in the right direction - thanks in advance
Problem: when I removed the transmision for the car, the mount only had two of the four bolts holding it on. After the engine/trans was removed I looked at the mount and the other two were stripped - thank you previous owner-
How do I get to the other side, and are the just nuts that I will need to replace?
Hope I explained the problem clearly
Is the holes for the transmission stripped? Or the actual mount? Or the body?
Generally either with tap. Or using a time cert.
Ther nuts that are tack welded in place. So sometime the welds will get corroded or over torque and break,
if you have a welder handy you have drill a hole on each side and then re weld them pretty easy. Or drill the holes and then take to a muffler shop and have them weld it real fast.
