R154 fill plug?
Freshmaker
396
Oconomowoc, Wi
A fair amount of oil dumped out of my tranny when I was putting my engine back in. Which plug is the oil-level bolt?
I thought it was the large bolt, 1/2 way up the tranny, near where the tranny mounts to the body. But, that bolt is Super tight. I wasn't sure, so I wanted to check before I really yanked on it.
the fill and drain plugs always seem to be really tight...
I use a jack (not kidding) to push up on a wrench to pop them free...
IIRC that is the bolt though, it's gonna be about the same size as the drain bolt...
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
they are exactly the same actually heh. the lower is drain the upper is fill
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
Don't tighten it so much when you are done.
Make it easier next time.
Frank Rizzo
478
Fixing your girl's car
Yea, but either way (from the top or fill plug) that fill plug is going to have to come out.
I prefer to do it under the vehicle, gear oil does not make a good car air freshener.
Mk3runner
2,033
Nor Cal
me, I fill from the top. doesn't smell and is far easier than using the fill plug. 3qts did mine perfect. redline mt-90 was my oil of choice.
