89mk3supra;1500651 said:
Can anyone recommened a clutch set up for a power range of 300-350hp? I am planning on making it my daily driver with occasional racing. I don't wont to buy something that will be noisy or give out quickly.
Here s the less expensive way you can go about
1. Stock toyota pp,toyota throw out bearing, pilot bearing Jay marks is a good source with discount once you mention the "supra forums".
2. The clutch disk is up to you a stage 2 will hold more power than a stock disk. If you dont mind the small amounts of chattering at low rpm go with a 6 puck disk they sell em on ebay for $$80 shipped thats should be no more than $240.00. This is the set up im running right now and have dyno to prove it 433rwhp 426rwtq
http://www.supramania.com/forums/showthread.php?t=108689
3. Now with the flywheel i personally like my XTD 14.5 lb CHROMELOLY STEEL flywheel. I have personlly have experience with the clutch set up above and with this flywheel since 2006 and no problems. I have had the flywheel resurfaced 2-3 times and still running like a champ.
I just saw that you live in Pamona, Ca Give Aaron at Driftmotion a call if you dont feel like doin some shopping on your own. He usually stock all the parts on his website good luck heres the link to his website
http://store.driftmotion.com/static/index.php
