I currently have a singled 2JZ and an ACT 6-puck spring clutch with the HD pressure plate (TS2-HDG6) and it holds fine driving around doing pulls on sticky tires at low and high boost (~350 rwtq and ~400 rwtq). However, I welded two of the six pucks badly to both my flywheel and pressure plate at a small parking lot drift event the first time out. :nono:
I've come to the conclusion that clutch kicking generates too much heat for my current clutch, and that I need something with better heat dissipation and probably more clamping load in case I up the boost later on. What are some high-abuse R154 clutches with a 500-600 rwtq capacity? Do I need to go twin disc? By the time I spend $2000 on a twin disc for the R154 (Which might fail in some other way at those levels with hard use) I might as well consider going V160.
What is everyone using for R154s that see hard use (drag launches, drifting, track use) and has it worked out for you?
