R-134A Retrofit Kit
LumbChuck
59
Charleston, SC
Is there a complete kit that you can buy to change over to R-134A ? I have searched through the threads and have not been able to find this . I know someone has asked this before . I would like to get a "Parallel Flow Condenser" with the kit . My original compressor (197k) went out , so I guess I need to go this route . I could use any info on this . Thanks
And this has what to do with turbo motor 7M's?
Thread moved...please pay attention where you post.
Jeff Lange
Administrator
4,922
11
Sunnyvale, CA
jefflange.ca
Jdub was referring to the fact that the 7M-GTE forum is for posting threads related to 7M-GTE specific topics. The A/C in the car is not a GTE specific topic and therefore does not belong in the forum you posted in.
As far as conversions. Toyota offers all the parts to do a conversion, but if you're looking to change/upgrade components beyond the original specifications, I don't know specifically where to get those parts.
Hopefully someone will chime in who has done some A/C upgrades on the A70.
Jeff
EDIT (Toyota Retrofit Information for A70 Supra):
88840–33020 - Retrofit Kit, R134a
88471-12070 - Receiver/Dryer, R134a Conversion Type
08885–09107 - ND Oil Type 8 (250cc), 120cc Required
90099-14120 - R134a Discharge O-Rings
90099-14119 - R134a Liquid O-Rings
90099-14121 - R134a Suction O-Rings
90099-14122 - R134a Pressure Switch O-Rings
R134a Charge Amount: 650g
Satan
Tampa
Do a search for parallel flow condensor. I had one made and retrofitted to R134a. Posted all the specifics, in this same section (I believe).
Kai
That Limey Bastard
08885–09107 - ND Oil Type 8 (250cc), 120cc Required (100cc for 1986 Models)
Jeff - whats the approximate line cost of each of these items?
