My TPS was bad so I switched it out with one that's good but it's a little bit different...
The thing I'm worried about the most is the numbers. On the old one, there are two lines of numbers the first one reading: 89452-14050, the second: 198500-0240. The one that works looks a little bit different, the face of it is a polished steel cap instead of black plastic and the numbers are 89452-14051, 198500-0240.
I'm assuming that the one that works is simply a newer one (perhaps off of a Post 89) and the differing number is just a part number to accommodate the new model.
Will this new TPS be ok to use in place of the broken one?
Sorry if this is a dumb question but I just don't want my car to blow up or anything so... I figured it was safer to ask than not to.
(Plug for WTB post: ) I also broke the wiring harness for the TPS so If you've got one you'd like to get rid of... :biglaugh:
Thanks for the help in advance.
