quick rod bearing question
kingofyo1
66
mountain home ID
so i was finally able to take down my engine/tranny, and as i found yesterday upon careful removal of my mains and rod caps i have a #6 spun bearing. seeing as it is the only bearing that even remotely looks bad or anything besides decent, is it worth the cost to totally redo the bearings or just the #6 rod bearing? nothing else in that bottom end looks bad or like it needs help, so id rather just as soon leave it alone as mess with it, but thats why i am here. should i mess with whats not broke to pre fix it, or wait till i get a bhg then redo EVERYTHING?
thanks guys
Drew
grimreaper
2,180
Dallas
Have you measured the clearances on the others? Your going to have to get the crank worked on one journal, might as well make them all the same. Plus you get to start over with bearing wear and oil pressure should be perfect again.
