Quick question on Parts
I6Boost
182
My Supra
The machine shop took .15 off my head and .16 off my block so in turn ill need a 1.6mm headgasket correct? if so the only place i can find that sells 1.6mm is www.sipracingmailorder.com, and its a SIP MLS Headgasket, im not saying hes a bad machinest or whatever but ive just never heard of his parts before. and all you guys that have MHG are using the hks/titan/greddy's in 1.4 or 2.0mm...
So has anyone had any experiances with his headgasket?
Also i need new piston rings, but only ones i can find are from horsepowerfreaks and there like OEM $250-$350!!!??
Is there any other piston rings i can use? I got stock pistons btw.
If so what company?
Thanks in advance for anyones response.
Koenigturbo
1,337
Oxnard CA
Total seal, Wiesco, J and E makes ring, there others, that's the ones that I'm aware of.
I would tend to go with the same manufacture of your pistons only because different pistons have different size ring lands,... but that's me.
I6Boost
182
My Supra
I found these, they also have 2 other options for total seal but again pretty expensive, as i dont really
plan on going for super high horse power goals. 350 at most.
&& Again what are everyones response on the headgasket aspect i stated above?
