Quick Help! Any issues with 6M Crank?
benk777
161
Waukesha, WI
I'm having legendofaces.com rebuild an engine for me, and the 89 core that he has access to has a 6M crank in it. Are there any issues with this? Should I hold off, or is this not a big deal?
Thanks.
Ben
jdub
Feb 10, 2006
10,730
Valley of the Sun
The 7M crank is smoother due to it's full counter weight design, but it's heavier.
The 6M crank is lighter and can rev a bit higher.
This is why you see the lower redline RPM on the '90+ cars ;)
Personally, I went for the best of both...a 7M crank lightened, knife edged, and zero balanced.
(before you ask...it cost a lot)
