Quetions On The 1JZ Power
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
aphxero;1209813 said:
Wow your powerband is pretty high up there. Spool makes it look kinda laggy but once you're in boost how's the response?
Are you holding tq with boost duty or do you have cams?
It pulls very nice. I have no cams. Dyno does seem laggy but it really is not.My turbo goes positive @ 2300rpm. at 3k I am at 5psi full boost hits at 3800 however, powerband hits fully at around 4400.
Then goes flatline til redline.
aphxero
787
Seattle, WA
Wow maybe I will try this for my next turbo. I'm wondering if my turbine is slowing things down up top? I figured the huge wastegate would keep that from happening. On my current setup I do get 1.0bar of boost at 3100 rpm. It feels like a blower :) But I want that top end son!
I have jzx90/jzz30 powerfc coming so maybe adding in some timing up top will help me out.
/thread jack.
ryangaudoin
Toronto
i also want to know if the jz series engines come with metal headgasket, cause i've been looking around and i've found out that some places say they come with metal gaskets and some sites say they dont, also some ppl have been telling me that as well.
im pretty sure the jz series engines came with metal headgasket's, correct me if i'm wrong
The head gasket is definatley metal. I have a brand new one if someone is looking to buy one.
I wouldn't say every gasket on the jz is metal, but the head gasket is.
ryangaudoin
Toronto
aright so im probably going to go with steel or metal turbines, as i have another project to get done.
Just want to know if i run with these turbines whats the most psi i can run like all day long everday is it 16psi??
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
if you are going through the trouble of pulling the stock twins, just go single. For the price of a rebuild with steel wheels in the 1jz twins, you can go single. IIRC they were around 1300.
stockers can usually deal with 15lbs daily. I have been driving with 15lbs daily for 2 years and i havent had any problems.
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
how much psi can the stock fuel pump handle?
1 important question also: my car was a 91 n/a swapped to 1jz, im still on stock fuel pump, is there a difference between n.a. fuel pump and turbo fuel pump?
Im looking to get a boost controller but im afriad of leaning out as i dont have a wideband yet.
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
Yes there is a huge difference. Intake exhaust and ecu made mine lean out on top end. Afpr and fuel dampner delete did little, then when I went walbro went into 10.5:1. I wouldn't suggest anything till you get a wideband and walbro.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
Wideband is probably the best tool on my car.. with stock y and 3" DP mine creeps to about 16psi and at that point I began worrying about inj. duty even though my WB tells me its not doing anything crazy.
in any case with FMIC/ piping, boost cut defender, 3" DP and AFC I made 340whp @ 16psi.. decent numbers are possible. (I really need to install the 440's though, dipping into the low 12's AFR is not too good)
ryangaudoin
Toronto
i didn't want to start up a new thread cause i think this will be short,
i think it's Carbon Monoxide in my intake cause im planning on replacing these hoses with reinforced silcone the but on the intake it's not as black meaning not as much in the intake, but in the intercooler piping it's real black and it's alot, i just want to know if this is normal or is my turbo's f**ed
carguy34
Denver, CO
I'm not sure what you question is, but you don't need to replace those pieces unless they have failed (cut, leaking, too brittle for comfort, etc.). As for the rest of your statement/question.....I've got nothing. What is it you want to know? Are your turbo's fine? Tell us something about what your turbo's are doing.....
ryangaudoin
Toronto
well my car is in storage and i took apart the intake side where the air filter is and it had black s**t, i think it's Carbon Monoxide in intake but im not sure, and then the rubber intercooler part that's on the intake side has more Carbon Monoxide really black.
i just want to know if it's normal
2nd does anyone know what the sizes are for the rubber pipes that are circled, i want to replace them with reinforced silicone cause the stock ones are ribbed on the inside just like how the outside looks
RockPaperSwoRD
Jul 26, 2008
392
SanAntonio
you realize that carbon monoxide is a gas? saying monoxide after carbon doesnt make you sound smart.
and to answer your question, take 1 of the rubber connectors out, walk into a auto parts store and find a replacement. not that hard
