questions Of Lexus AFM, need help
aaronmancilla
Los Angeles
ok Guys finally I got the Lexus Ls 400 AFM,
I installed the AFm on My 87 Supra and for some reason it did not work
the car wanted to turn off, any Suggestions?
do I have to go with the injectors 550 at the same time with fuel pump 244?
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
umm use the 7m electronics in the lex afm housing.... and see if that helps. You should be able to run without any other modification. However you need to read up on the mod first. Alot people say you will run lean and other say you will be fine if you reset the ecu....
aaronmancilla
Los Angeles
how would i reset the ecu?
