Just some input from personal experience here.  I had a Holest HY35W on my supra which i bought from Jon at MDC (thanks for all the help with that whole fiasco Jon!!).  with a stainless steel tubular manifold and 50mm external w/g all supporting mods i had FULL boost at 3200rpm.  dont know what my egt's were but i never had it over 19psi on pump and anything over 7psi had water/meth spraying.  However, it made awesome power.. at 10psi i walked allll over a modded LS1 camaro (i have video).  i bought some Torco 110oct leaded fuel and cranked it to 26psi. my Spec 3 clutch with 6puck feramic disc was slipping in 4th gear.. no traction in 1,2,or 3.  It is a fantastic turbo, i had no complaints other than figuring out the over-oiling and under oiling issue we had.  I'm ditching that turbo for a bigger unit.  And if anyone uses this turbo, you WILL.. absolutely WIILLL need to go external w/g.  that turbo will over-boost like freaking mad. the stock w/g can not let out enough exh. gases.  even if you port the w/g hole.
Also, the a/r on my holset is .69 compressor side and .89 turbine side as a side note. its the 12cm2 housing iirc.
Supra kid 101... If you want help or input on putting this turbo on, PM me ill give you my cell # and we can talk.  I also have a few things you will deff. be interested in knowing, but too much to type here.
