Question
supraman11203
BLack CRessIDa KiLLeR
Jul 18, 2006
63
NYC ,brooklyn
Is there a difference between the aristo harness and the US Spec 6sp harness? And are they're limitations with the aristo harness?
__________________
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
__________________
Yes,
I believe the Aristo Harness is Map based.
Us is MAF based.
tissimo
Stock is boring :(
Melbourne, FL
usmkiv harness
Maf based
Extended for LHD Car
Wired for Resistor pack
Completely different wiring for the body
Igniter on the Left side of the car
thats about all i can think of right now
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
im not 100% sure but the auto transmission from the aristo looked a lot different (output shaft, so maybe the plugs are different too) not sure if the mkiv's harness is seperated from the autos harness but i noticed right away the auto harness on the tranny is integrated into the aristos harness
my only problem with the aristos harness was the coil plugs were mush from the years of heat and needed new ones
mobes
Supras are never 'done'
Bozeman, MT
tissimo
Stock is boring :(
Melbourne, FL
aem piggy back? It will work i guess. No one has tried it that I know of. VPC can work, but isn't needed. A VPC Is a deviced used to convert a MAF Based car to a Speed density setup to eliminate the maf.
tlo86
Jul 24, 2005
3,914
Colorado
supraman11203;935075 said:
so can the aristo harness be used with the us spec ecu
tissimo did something like that i think... why do you ask? are you looking for a non piggyback solution for 550's or something?
tlo86
Jul 24, 2005
3,914
Colorado
supraman11203;935211 said:
no im just trying to find out what harness should i use for my swap
lol why didnt ya say so :D it doesnt matter if you use the MKIV harness or an aristo either way you need to wire in the body plugs. dr tweak is the easiest way imo
