Question on jdm swap
pauly
jackson,tn
I just purchased a JDM 7mgte 90 year model,But my car is a 87 will the wiring and sensors hook up? IF you have any tips or other information on doing this project to save me time It would be much Appreciated.THANKS
supra90turbo
shaeff is FTMFW!
MA, 01440
More Info!
Your car is an 87 Turbo? NA?
My car is a 90 Turbo and when I got my engine, it was a pre 89, so it was a bit different. All you have to do is remove whatever's different and replace with your other parts.
shaeff
Kurt is FTMFW x2!!!!
11
Around
you need to keep the wiring harness from your '87, and put it on the '90 motor. you'll need to splice 4 one wire connectors at most. it's very simple. keep the ECU and HAC sensor that you have. :)
-shaeff
