Trying to get everything buttoned down before I drop the engine in.
#1 Vacuum line that goes across the timing belt cover... what does it connect to on the left hand side of engine?
#2 Shown below is a nipple of a vacuum line that runs parallel to the IC 3000 pipe. You can also see another nipple that has a bolt down tab; this is the piece in question. First off, is connecting these two nipples the correct hose routing? Does the tab use the same bolt hole as the coil pack ground strap?
This is a picture of the piece in from below.
#3 Also looking to obtain a VSV sensor, O2 sensor plug wire both male and female ends, and a cam positioning sensor (wires or the whole thing). I live in the Kentuckiania area and am willing to drive for these pieces.
Please help straighten me out, Thanks!!!
