Question for any old school MAF-T users.
Intothenight19
Crissaegrim
Feb 23, 2006
221
Pa
Well, I just wanted to ask if anyone who is using the old MAF-T is using the GM MAF in blow-through mode or any other way. The reason I ask is my A/F ratios get pretty crazy at initial start-up, such as off the charts lean. Then after the car warms up a bit they go pretty rich at idle, 12's. Then I'll drive it around and I can't get under any type of acceleration till the car fully warms up, even then I have to re-start my car to accelerate at all. After the re-start I can boost away but the A/F ratios go extremely rich at idle 10.0. And 12.2-13.4 cruising. Im running about 40psi fuel pressure off vac, my tps sensor is unplugged right now because my countless attempts at calibrating it only lead to failures. So im expecting to be running richer with the tps being unplugged, but the start-up A/F issues seem odd. Maybe a bad CSI time switch? I plan on going MAF-T Pro soon, but I don't have the funds and would like to find out why my A/F issus are so wacky... Any ideas? And could running my MAF in induction mode (on the intake pipe) change anything? Thanks all!
Intothenight19
Crissaegrim
Feb 23, 2006
221
Pa
I guess we will never know. Running super lean then super rich is quite annoying though. I hope to put a bit of money together and buy an AEM unit and do away with this MAF-T bs.
drjonez
the motor city
www.4cefed.com
Intothenight19 said:
...my tps sensor is unplugged right now because my countless attempts at calibrating it only lead to failures....
you can't expect the ECU to do anything predictable when you eliminate one of its primary sensors. pull the TB, read the TSRM, set the TPS. as always, make the car run right BEFORE modding it....
