Question about fuel injectors
borisupra
26
Bayamon
Hello people,what kind of factory injectors the 7mgte have and how much cc's would be considered efficient for a slighty mod Supra MK3 i mean a bigger turbo ,intercooler, 3" inch exhaust just a start thanks
borisupra
26
Bayamon
Just factory specs i just bought it while i was on leave and im in iraq so i cant work in it till im home in around 4 months so im just in the planning phase
89nasupra
Sugar, Water, Purple
Apr 8, 2008
501
Lafayette, Louisiana, United States
Oh ok gotcha. You will notice that is a popular up grade for our cars. There is a few write ups on here if you just search alittle.
On a nother note, My family and I would like to thank you and all fellow service men and women for what you are doing out there.
How much bigger will the turbo be?
stock injectors and fuel pump max out around 330hp. Stock is only 230hp.
borisupra
26
Bayamon
---------- Post added at 12:24 PM ---------- Previous post was at 12:22 PM ----------
[/COLOR]
--------Thank you for your support really apreciated
---------- Post added at 12:28 PM ---------- Previous post was at 12:24 PM ----------
Dont know yet stillin the search phase on that one you have any recomendations?
figgie
Twin Cities, Minnesot-ah
If you never driven a 400rwhp car... i suggest you start with 550 and the lex afm. This is the most inexpensive route to go with. Otheriwse you have to invest in piggy backs or standalones which will quickly quadruple the price tag.
89nasupra
Apr 8, 2008
501
It depends on the condition of the AFM. Guys help me here, if I'm not mistaken you can use your current AFM electronics and just swap out the housing. I remember reading something about doing that but not 100% sure on it.
SideWinderGX
733
The housing is what you are interested in, look in the for sale section, they're pretty cheap. You can use your electronics or the Lexus' electronics depending on what part number is on it.
The Lexus part number that works is one more than the Toyota's AFM part number.
Supra0089
367
New Hampshire
I'm in the process of doing this upgrade. Here is what you're looking at:
550cc Injectos ~350-400
Lex AFM ~75-100 (used)
AFPR ~120
Wideband ~175
Fuel Pump ~50-75
Prices will vary depending on what brands you get, and who you're supplier is....
Koenigturbo
1,338
Oxnard CA
Question: are you saying with this set up, he does not need a piggy back or a A.P.F.R.? From reading here, most everyone recomends a A.P.F.R. and possible tweeking of the air screw in the Lexus A.F.M. I think possibly you forgot to mention that, I could be wrong.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
With lex afm and 550's you don't need a piggyback. If you stick a walbro pump in the mix, you will need an AFPR. Well, you don't need it but you will at least have to drill out the j tube and it is recommended.
Koenigturbo
1,338
Oxnard CA
Whtma71, that's good answer. what's the cut off point for as far as boost on this set up? Can you go 18ish?
89nasupra
Apr 8, 2008
501
What would happen if you just bypass the J-tube with the stock regulator?
Nothing. You only need to drill/ bypass the j-tube if you get a bigger fuel pump. The tiny hole acts as a back up fpr just in case the fpr goes bad.
89nasupra;1561013 said:
Oh ok. So you only need to bypass/drill out the J-tube if you want more adjustability out of the aftermarket regulator?
NO> You only drill/bypass if you get a bigger fuel pump.
