Question about all HKS F-CON systems
jailbird25
53
Neugersdorf, Germany
i have a question about the F-CON systems for a 7MGTE!
In this time it gives many F-CON systems ( pro,V,gold,S,SZ,IS)
Wich one can instal in a /MGTE exept the old black F-CON.
So i search instal instructions,pics and all other informations!
My idee i will install a data logging F-CON with many functions.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Yes, yes, and yes. They all have plug and play harnesses for the 7M. (or if they don't, a universal harness can work)
It'st just a question of how much you want it to control.
(I run a V-pro on a 1JZ if it matters to you.)
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
who tuned the V pro for you & for how much? i was thinking of getting a V Pro for my 2j
jailbird25
53
IJ. said:
JB: For your goals a Standalone would be better suited.
the F-CON V PRO is a standalone management system with a data logging mod.
On the HKS Web sites i can not find any informations for a 7MGTE Supra and informations for the instal!
so here my Question..in germany gives not a HKS dealer!
Ahhh ok not familiar with the Pro sorry.
Very little information available in Australia on it.
MattOneDizzle
URPHUKDNOW
Feb 4, 2007
63
Portland, OREGON
No the V-Pro is not a standalone system.. It is close to it, but not standalone(Although you could make it one, but we wont get into that now.. lol). Things like idle control, relay activation, ect.. remain controller by your factory ECU (since the VPro is piggybacked into your harness).. They do not make a P&P harness for any 7M series motor. The 1JZ and 2JZ (of all ecu configurations) are available however. Making one work in a 7M would require you to adapt your CPS as well as install a crank trigger. So pretty much if you are looking for a P&P EMS for a 7M, the AEM is your best option.
As far as tuning, we offer travel tuning services and our main tuner (John Reed) is frequently tuning in Germany. We are an HKS Certified Pro dealer.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Ah you're right, the don't have a PnP harness for the 7M, so a universal harness would have to be used, but why would you need to adapt the CPS? I'm sure the V-pro could run a waste spark system. Hell, if it runs on any 1JZ or 2JZ, I'm sure it could handle a 7M.
As for the V-pro not being a standalone... Out of the box is does piggyback in, and leave some things under the control of the stock ECU, BUT it doesn't have to. The V-pro can control them, and run in full standalone if you want it to.
I got mine tuned at RCTS here in Calgary (www.monsterhorsepower.com). The cost of tuning was pretty cheap, he just flashed another setup from another JZA70 they have at the shop, then spent an hour with it on the dyno making sure it worked out. Now, cost for materials, that's a different story ;)
