Question about 89+ Tails
Just a few days ago i noticed that the trunk lock has fallen off from inside the center piece of my tails.
does anyone have a pic of what it is supposed to look like inside that center piece around the lock area?
I didnt install the tails someone else did... and beginning to notice the sh*tty job he did...
:nono::3d_frown::cry:
Sep 10, 2007
482
Virginia
when I switched to 89+ tails, I had to epoxy my stock lock cylinder into place because it mounts to the center piece differently between the two styles. mine works fine, I am just easy on the key when unlocking.
sounds like thats what the previous owner did, but not well, and the lock cylinder snapped off. I would just take it apart, and re-attach the lock cylinder the best you can with some good metal and plastic epoxy, and keep the 89+ tails (wayyyy better IMO).
GL
Hey thanks for the tip and advice on keeping the tails...
is this the problem for all the tails i mean 89+ or just us who switch over to them???
you tried just the remote access... not the inside cable but the actual push a button and pops the hatch???
anyone here on SM have it or one???
let me know and give some recommendations if you have.. might be a better choice for me anyways....:3d_frown:
Sep 10, 2007
482
Virginia
The problem is in keeping your stock lock cylinder. The inside cable still works fine, because it doesn't use the lock cylinder, it is a separate cable.
I'm pretty sure that if you used an 89+ lock cylinder, that it would just bolt into place, but the key would be different.
not too sure what your asking about a better choice tho...
5
I'd have to look at both lock cylinders, but it might be possible to swap the two assemblies after disassembling the lock...
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
you can get an 89+ lock cylinder and then get it re-keyed to your original key. I locksmith should be able to do it.
5
see, the only issue is I think they changed the entire key design in 89, but I'd have to look it up...
