Q45 Tb Diagram?
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
I'm using the Q45 TB on my FFIM and I can't find the vacuum diagram for it, do any other FFIM running the Q45 tb have it, or know it?
chevyeater
wastegate hose is pulled
Long Island, NY
What diagram? There are two ported vacuum holes (99% of people just block them off) and two coolant fittings on the Q45 throttle body. Epoxy works well for permanently blocking the vacuum fittings off, so you don't have to worry about some stupid cap blowing off on boost. It is also a good idea to remove the throttle kicker linkage if you aren't running a standalone/ do have an ISC/ are not running the coolant lines to the TB.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
-Running the AEM EMS
-Do have the ISC
Do I need the coolant lines to the TB? What are the effects of blocking them off? Or what needs to be done to run this way? Thanks.
turbogate
Life is Boost
May 18, 2005
425
South, FL
There's no effect to blocking them off. As a matter of fact, I didn't do anything with my Q45 TB coolant line, I just left them alone. All I did was loop the TB vacuum lines with one vacuum hose.
chevyeater
Long Island, NY
-Do have the ISC
The coolant is responsible for operating the throttle kicker. That is why I said to rip it off if you aren't running coolant thru it.
