!!!putting n/a in place of turbo engine help!!
demolition man
ct
quick question i plan on using the turbo wiring harness, do i need to use the coil pack to hook it up of will the distributor on the n/a hook up and work fine?
f00g00
586
Kuwait
I don't believe its possible to use the distributer with the coil packs and igniter, it would probably work if you use the CPS with that setup. With the NA distributer you would need the NA coil and no coil packs, just straight wires from the distributor cap to the plugs.
demolition man
ct
i mean are the connections on the connects on the coil pack and distributer the same? or will i need to put the cps and coil pack on
f00g00
586
Kuwait
Use the coil packs and CPS. The coil from the NA doesn't look compatible with the GTE computer, and the distributer is only compatible with the NA coil due to the coil wire.
demolition man
ct
the connection on the distributer and the coil pack are exactly the same? im going to give it a try first before i change the cps, valve covers(so the pack mounts up), ect. i just dont know if the cpu will register it as the same thing. hopefully it will work but if not it will solve someone else's problem down the some day
lagged
1991 1JZ
new rochelle
regardless of how you want to run the engine, i have an 7mGE in GREAT shape with auto ECU and auto tranny. no harness though.
