pump sound?
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Well i noticed recently that when i start my car, doesn't matter how long i let it idle and warm up, and start to drive....i hear a Pump of some sort, i guess pumping up for about 3 seconds, i have abs and it comes from that side of the car but brakes and suspension is my weakness when it comes to cars....except drum brakes(i have a old nova with 4 wheel drum, so i've rebuilt many of those in my day:])
I have an automatic tranny, i say this because it only happens whenever i put the vehicle in drive after starting the car from a cold start.
Any idea what might be going on?
jetjock
creepy-ass cracka
9,439
Could be the ABS pump going through it's self test. On manuals that happens right away but on autos it may wait until the car is taken out of P or N. I say that because the NSW is connected to the ABS computer but I dunno for sure. Either way if that's what it is it's not a good sign he can hear it.
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
well i had a range rover that had 4 wheel abs and it started up...making a similar sound....
It not a rattling noise, just sounds like a pump engaging, a vvvrroooommm noise....kinda like when an a/c system turns on in a building....for that first 3 seconds...
Finnon
701
South Shields, Tyne & Wear ENGLAND
my auto supra buzzes once the car gets past 4 mph. It says it does that in the handbook. its very quiet tho so maybe you guys have missed it before.
My sierra self tests its abs when the ignition comes on and makes quite a loud buzzing sound for about 20 seconds
jetjock
creepy-ass cracka
9,439
Now that I'm home I took at look at the books and it's what Finnon said. Solenoid and pump tests don't occur until speed exceeds 4 mph. If you want to know for sure if that's what you're hearing depress the brake pedal enough to turn on the brake lights and go above 4 mph. The test should not start until the pedal is released.
CJA
Melbourne Florida
i had a similar problem to this my intake manifold had came a little loose and it made a weird sound and stalled as soon as it was any kind of gear maybe make sure everything is snug?
