puff of smoke???
PRpimp3o3
da puerto rican supra man
Apr 2, 2005
117
CO
Well i just finished up putting in my JDM motor and everything has been going good breaking it in. Then this morning when i went out to the car and started it a puff of smoke came out the exhaust. It dosent come out right away its about 2 seconds after its started but then no smoke afterwards. I can turn the car off and the start it back up and another puff of smoke will come out, then no more smoke. anyone else had a problem similar? any help is appreciated thanks
Rico
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Rico
What color is the smoke. White I'm thinking..
I had this problem due to bad valve stem seals. That's just my thought.. however if you let the car run for a couple of minutes and then turn it off and start back up will it happen? Have you checked your plugs?
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
Now, I'm not going to be the one to jump to conclusions and scream ::bhg:: , however...
This was one piece of my bhg puzzle. The other thing that went along with it was the dreaded puddle of coolant under the car when I would park it after a good run, since the pressure would climb and it would belch out of the overflow. Not saying it's a bhg, but it might be time to keep an eye on other tell tale signs...
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
i agree. i dont think mine does it anymore after the BHG fix...but it used to smoke a tad bit after startup, especially if i tapped the throttle. but its cold where i live sometimes and ANY car will have some smoke...but mine was more than that. now it seems fine.
keep an eye out for BHG...catch it early if there is one and save $$$ on repairs.
PRpimp3o3
Apr 2, 2005
117
CO
i have already replaced the hg with a hks 1.2 and put arp headbolts so i dont know why it would be bhg. idk maybe but i hope not
Figit090
Jan 7, 2006
1,835
Humboldt County
metal HG? dont know from experiance but word is you need to deck the block for a metal gasket for proper sealing, my guess is you did that if you have an all metal gasket.
PRpimp3o3
Apr 2, 2005
117
CO
ya i did plus got the head milled just so i would have a nice smooth surface. so im still confused but i guess ill just keep an eye out for anyother bhg related things thanks everyone
