Project Git 'er done!: Stages 1 through5- ***14 YEARS....Approaching the finish line!!!***
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
Update:
As of 5 days ago, the engine is back in the car, reconnected, and started successfully on the second try.
Surprisingly, there were NO leaks whatsoever. In its current setup, the oil cooler circuit is bypassed, so that I could run the engine up to operating temperature(twice), and have already changed out the oil and filter, to remove any metal/ particles. I will do a 2nd oil change in about 500 miles, and then reconnect the cooler system at that time.
Here's an interesting issue I've had, ever since I installed the BC cams: I could NOT set ignition timing to the proper spec.
On one CPS tooth, it would be a minimum of 20 degrees advanced, and on the next tooth, a maximum of 0 degrees. I could not get it any closer using the adjustment range of the cps. My conclusion, is that BC didn't really pay attention to the drive gear alignment, when they cut the teeth into the exhaust cam.
But here's the interesting thing: I pulled the cps, planning to remove the drive gear, and redrill a new hole, to shift it's position by half a tooth. But- I realized that there are 13 teeth on the gear. If there were and even number, that would mean that however one side of the gear lined up to its dowel hole, the other side would be identical. but because there are 13, the opposite side of the gear lines up exactly half a tooth off from TDC alignment. Hopefully that makes sense.
What it meant for me was, all I had to do was pull the gear off, and turn it 180 degrees, in order to get a middle ground, between my too-retarded and too-advanced timing points. Now I get 10 degrees btc, no problem. So that's one more issue solved.
As far as I can tell, I only have one issue left before a test drive: The three coolant hex plugs in the center valley of the head, are ALL weeping coolant when fully warmed up. I don't know if the machine shop removed those for cleaning, or if cleaning the head externally has eroded the sealant on them or something, but I have to pull them and reseal. Not a big deal, hopefully.
My one concern with the engine was the vacuum: I was getting 20 inhg before, but with the cam swap, I only get about 14 inhg. I did some online reading however, and apparently, this is exactly the number I should be getting with the stage 2 cams.
So hopefully this coming week, I will finally get a chance to bring this car onto the road, and actually drive it for the 1st time since the Green Bay Packers were Superbowl champs. :rolleyes:
PS- Pics to follow.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
I know that i promised pics, and they are coming, but i thought i’d update while I had free time:
I was able to remove and re-seal the front and rear coolant plugs, but that middle one will NOT budge.
I’ve heated it, added PB blaster, and used both breaker bar and impact gun, but all I’ve managed to do, is mess up the
plug’s hex socket. Its a 14mm hex, and i went up to a 9/16 hex, to make sure I had a good bite on it, but it still wallowed out.
I was using both a propane torch and a heat gun, but I dont know how far that heated the head. Still was barely warm.
So my plan at this point, is to put the piping and coilpack back on, and run it up to full temp, and see if that helps at all.
If not, i‘m likely going to have to bring the car to a shop to remove that plug.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
Welp, that worked.
I ran the motor for 20 minutes, until it was at full temp, and was able to Finally get that center coolant plug out. Looking at it, I'm pretty sure, that I only had one last attempt, before it became a perfect circle, and stripped out completely:
I was planning to pull a coolant plug out of my spare head, and honestly, dreading the prospect of trying to get it loose, when I vaguely remembered that I once bought a plug from the dealership years ago. I was trying to order one of the plugs that hold down the center valley cover, but I gave the wrong part number, and wound up with a lower coolant plug. I started looking through my fastener drawers, and sure enough, I still had it, brand new. I never thought I'd get a chance to actually use it, lol.
Engine is running pretty smooth, and once this cold snap in the weather is over, I will take it for a short drive.
At present, I have the AFM connected, and the original 440cc injectors. I will switch over to MAP and 680cc's, once I have some data logs.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
Ok, I freaked myself out the other day;
I was running the engine up to operating temps for about 30 minutes, as I was also trying to check the DET3 connections through my laptop. All of a sudden, I see a bunch of blue(OIL!) smoke coming out of the exhaust! I'm like- "Oh sh!t... I am NOT pulling this engine again....No way." Well, I quickly realized that the Tstat has stuck closed, and I was beginning to overheat. I didn't get to the redline, but it got close. I replaced the brand new(sitting in coolant for 8 years) Motorad failsafe, with a Stant ultrastat, and the issue went away. I believe the exhaust has a TON of half-burned oil in it, and I think it was beginning to finally cook out, due to the higher temps. Next time I started it, I ran it again for about 30 minutes, zero smoke. So hopefully, all it was, was old caked-on residue burning off.
Haven't done much with the car this week, because I loaned my AFM to a fellow Supra owner, to test his car with.
In the mean time, I've been trying to finalize the gauge cluster, and also did a bit of messing around with the vinyl wrap.
Here's a sneak peek:
The orange color looks really bright from this angle, but its actually not nearly that 'neon' in person, and more metallic looking than it appears here.
Still have to do the other side, and maybe play with a bit more wrap on the hood.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
So as for the wrap job, I didn't have enough of the orange left to do the other side, so
since I had to order more, I ordered a sample of what I hope is a slightly darker version of copper-orange,
so that it matched better with the wheels. We'll see in a few days.
In the meantime, I'm still doing some wiring, but I did finally get the IAT sensor wired in and reading properly.
And today, I installed new rear lugnuts, since these black ones chip every time I have to pull off a wheel:
There's plenty of thread engagement, but I may opt to replace the rear lugs with even longer ones, not sure. I still have to put on the front extended lugs, but I'm not looking forward to the labor involved in that.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
Graphics are finally completed.
If you think its a bit too much- you're probably right.
But that was the whole idea of this car; just a bit farther than comfortable for an everyday car.
  • Wow
Reactions: loc182
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
Well guys,
I'm down to a single page of to-do items, left on the car.
Some of them are as simple as aligning the headlights, and installing the glove box, and others are a bit more labor-intensive, like fabricating a fuel pressure regulator mount, and creating engine logs.
But overall, I think I'm down to a week to 10 days of labor. At least I'm hoping so.
Today, I installed extended front wheel lugs, a few various wiring issues, and also installed a new set of front upper A-arms.
I had a issue with the front wheels/ tires, being too wide, and they would rub on the fenders even with full factory camber.
I bought the Agile performance adjustable arms, And they allow me to increase the camber slightly from the top, so that now I don't rub anymore. I will probably pull a bit of the camber back out, using the oem adjustment bolts.
Tomorrow, I hope to finalize the gauge cluster, and reinstall it. Once that's done, I should be able to put on the steering column covers, and lower dash finish panel, and install the climate control unit and surrounding bezel.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
Well, still working on the gauge cluster, but I did finally discover WHY my temp gauge wouldn't read right:
I would set it to the 'C' at the bottom of the gauge, and turning on the ignition, the temp would shoot to full hot. I replaced the temp sender, and tested resistances at the gauge and the harness. I ordered a replacement temp gauge off ebay, and then putting it in my car, and it started acting all weird as well.
Now, let me preface this with the fact that I have installed aftermarket gauge needles onto my gauges, and they took a bit of work to get fitting correctly. The reason the temp gauge didn't read right, was because both the temp gauge and the fuel gauge oem needles incorporate a 'limit ring', which keeps those needles from falling to the bottom of their gauge faces. I finally noticed this, and after some modifying of the new needle, the temp gauge works perfectly.
So perfectly in fact, that it showed me that I was overheating badly in the driveway. After checking the brand new thermostat, and seeing that it was indeed opening properly, I checked the 'brand new' 10 year old fan clutch, and it was loose as hell. I could stop it by hand while the engine was running, and even spin it backwards. So much for Four Seasons parts.
A new Aisin unit is on the way.
30 items left on the to-do list, and counting down.
  • Wow
Reactions: loc182
supraguy@aol
Well-Known Member
Dec 30, 2005
4,273
64
Atlanta
Okay,
Down to 20-ish items. Aisin fan clutch is installed. But I found that one of the temp sensors on the Tstat housing was leaking, so now a new sensor is on its way.
The gauge cluster still isn't closed up, but that should happen tomorrow. My final task with that, was to calibrate all of the needles to their correct positions. So I thought that the easiest way, would be to start with a cold engine, turn the ignition to the ON position, and set temp, tach, oil pressure, and voltage. For the fuel gauge, I decided to pull the level sensor out of the tank, and physically move the float to the full position. That way, I could set the needle, then drop the float to the empty position, to make sure it still aligned.
BUT. I quickly found out that my fuel sender was bad! "Worked when parked" as they say. But I guess 15 years sitting at near empty will take its toll. I took a quick look online, to see the price of new senders, and immediately said Hell no. The only place I could find to get one online is Ebay, and they're charging $330+ for them. Meanwhile an AE86 fuel sender(same style, with low warning sensor) is $40. WHAT?
Anyway, I opened mine up, and started checking for continuity.
That metal tab marked '186' had no electrical contact with the metal plate below it, even though there is direct metal to metal contact between them, via a spring. No mater what I did, I could not get continuity. As a final attempt, I simply sprayed the whole assembly with battery contact cleaner and let it soak for a couple minutes, then sprayed it out with afm cleaner. BINGO!- continuity. I guess all of the contact areas were simply glazed over with gas residues or something.
So, tomorrow, I'll try once again to finish the cluster install.
After this, I decided to troubleshoot the washer pumps, front and rear. I replaced the washer tank a few months back, with the 89+ style, which has a black lid, as my old one had fallen apart, and they're no longer available. I also swapped over one of the pumps, since the plug is different between years.
But I come to find out, that both damned pumps are seized! What the hell? Again, they worked when parked, so apparently these cars don't appreciate being sat in the corner for decades.
ANYWAY, 2 new pumps are enroute as well.
