Problems with my hose. Nope, not those.
Crazybobmundo
105
Nashua, NH
Im at the point where Im replacing my hoses but theres one that I cant find. Toyota Cant help me because they searched and searched and cant get a part number.
So I come to you guys.
The hose is attached to the coolant pipe that wraps around the block....
and I believe it goes around the back of the block to attach to this heater hose on the drivers side.
I hope someone can help me. Thanks.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
The outlet in the first picture is only there on early model Supras - not sure what year it vanished, but I haven't seen it on any cars '89 or newer.
Furthermore, it's not connected to anything, just closed with a cap. Unless you're referring to a right hand drive car, of course.
Dirgle
Conjurer of Boost
Pauma Valley, CA
If I remember correctly the coolant pipe you have marked in red has a rubber cap on it for USDM. The JDM version of the MKIII has the heater core on the other side and it plugs in there.
For you, your heater return plugs into the pipe on the other side that shows a cap on it, and the rubber cap goes on the pipe you have marked in red.
edit: Damn, Grimjack beat me.
Crazybobmundo
105
Nashua, NH
oooh. Well that explains it....
The 90 I bought came with 2 engines, a JDM and USDM. I put one engine together with parts of both. I must have gotten that pipe from the JDM engine...Cause the other side is brazzed shut. It doesnt have the rubber cap most coolant pipes do.
Well this sucks...Now I have to figure out weather to swap out that pipe or cut the brazzed cap on the other side...It wont be an easy task though.
Thanks a bunch guys.
