problems with my baby
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
she hasn't been runnin well at all latley. no power at all, she bogs down on any hill and hasn't built any boost in months. i'm not leaking oil, i'm not blowing and smoke no error codes and toyota says she's running fine but she really isn't. i need help so any ideas you guys have helps out tons. thanks guys
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
Check to see that your bypass valve is working correctly, and check your spark plugs. Also look for boost leaks.
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
is there anything else that i should have a look at. with no codes to go on i can't really start at one place. there isn't anything visabley wrong. the hoses are a little worn but i'm replacing them all with metal. even goin up hills the RPM's drop. she has no punch left so i'm a little worried it's time to give up on this one
SupraMario
I think it was the google
7
The Farm
It really does sound like spark plug problems, the gaping may be off, or thye just might need to be replaced.
if its not showing the common signs of BHG then its prolly not BHG.
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
thanks guys i've got some work to do. if you guys can keep pumping out the options that would be great. the more the merrier
Maroon88
I collect BHG's
May 3, 2005
50
Cincinnati, OH
Has it run correctly since having the BHG repaired? If not, I am betting they didn't get the timing between the crank and cams correctly.
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
yeah i was running fine. even with the BHG it was running great. there was no noticable difference when the replaced it but now she is just running like junk so i don't know how to explian it
