problem with Power Steering (2jz mk3)
steveyblack
529
Nj
Hey all. I have a problem with my PS. I just replace the pump and after I bled the system. I jacked the car up and went full lock left and right a couple of times. The fluid level didnt really drop too much. BUt its up the the appropriated line. Now the problem happened when the car was on the ground and turned on. It was lovely to turn left and right, but once I went full lock right, my steering wheel got slighty stuck. It clunks back right before full lock but after that the system seems to have air back in it, the pump wines when im turning at slow speeds. I bled it again and found out that full lock left is fine and its only full lock right. Any ideas? am I over extending the rack somehow? The steering wheel doesnt get hung up when the car is off.
Bleed it with the wheels on the ground. Go full lock hold for like 3-5 sec and then go the the other way.
