this is for a w58. cable spins freely, but still nothing. to remove the gear will i need to drain the fluid? also i have one out of a mk2 will that work? anything eles i should look for?thanks
No, the mkii gear won't work. It's too small. You should be able to get another gear from the dealer, if you need it. You shouldn't have to drain the fluid, although it might drip or dribble a bit. Pull the speed sensor, and the gear is clipped on the end.
