Problem with fuel system
Status
Not open for further replies.
splitzhail89
Banned: Scammer, liar, cheat and thief
Jan 11, 2006
Nampa, Id
Hello, just got a new fuel pump put in, but the car hasnt ran before. I have spark, and i have fuel pressure, now i dont have any injector fire. Somebody help me out. What could cause this?
-Adam
8,897
No power to the injectors is a likely cause. The ECU only supplies the ground path.
I am assuming none of the injectors are pulsing, and you really do have spark.
splitzhail89
Jan 11, 2006
Nampa, Id
Yes none of the injectors are pulsing. And yes there is spark. I really need this problem figured out. Thanks ahead of time.
-Adam
splitzhail89
Jan 11, 2006
Nampa, Id
Comon does anybody else have any info on what could be the problem, i really need my car back on the road.
-Adam
dbsupra90
toonar
indiucky
do you have the resistor box plugged in? if you dont know what im talking about its the silver box with fins on it behind the driver side strut tower.
i would also check the resistance of the injectors and they are plugged in tight.
splitzhail89
Jan 11, 2006
Nampa, Id
Yeah, the resistor box is connected, and the injector clips are plugged in tightly. What other problem could i have?
-Adam
8,897
There is no other choice. There are two things needed to fire the injector, power and a ground source. Dude. It is one or the other, and the ECU provides the ground path. You never said you had B+ to the injectors.
All grounds must be good.
Status
