Problem dying after boost....cash reward!
supraman502
not lazy, just dont care
Apr 8, 2005
326
louisville, KY
chevyeater;948066 said:
I had a good one over here recently.
Kicked my ass for a while before I figured out that every time the fuel pump switched over to 12v operation it would pull the voltage on the EFI circuit down to ~7v (aggrivated by electric cooling fans). Car ran fine at WOT and most times but would stall intermittently, usually after throttling it good and would not restart for about 10 minutes if it was shut off hot or stalled at a light. It would restart with a clutch bump though. Rewired the fuel pump (HKS in tank) with a relay to B+ and it is perfect.
mines already been rewired......
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
IwantMKIII;947797 said:
arnt the sensors in the IC piping? typically anyway? what if the SD sensor was before the BOV and thats where the leak was?
GrimJack;948077 said:
The temp sensor can be anywhere post intercooler, technically, but it doesn't work well in areas where there are lots of heat.
The SD sensor (It's actually called a MAP sensor) has to be post-throttle body. Otherwise it would ... well, run really rich when the throttle plate was closed. Damn, sounds like the symptoms described!!!
supraman502;948369 said:
it has a 3bar map sensor, the vac line is connected directly to the intake manifold. The temp sensor is the one that came with the speed density kit and its mounted about 6" in front of the TB
So, the SD sensor runs off a vac line from IM? Or the IM has to be tapped for the SD sensor?
BillyM;948332 said:
The next person who says "bov is sticking open" should get a one-week ban.
billyM
:nono:
MDCmotorsports;948354 said:
Bov is sticking open.
:biglaugh::biglaugh:
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Sensor can be mounted directly into the manifold if you want, but a line to it works just as well. This is how I have mine setup.
I'm willing to bet the code 51 is the problem. Have you run through the adjustment procedure for the TPS? Code 51 means the ECU thinks the throttle plate is open...
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
might also be the location of the iat sensor. i had similar stalling symptoms on warmer days when i had my iat sensor in that same location. there was waay too much heat soak from the motor and the turbo.
bring up manifold temp on the sensor monitor and remember what the temp is. then while cruising. then at idle after cruising. then while boosting
after the car dies you'll see that the manifold temp goes up pretty damn high and the car doesnt want to run
a_sesshoumaru
Suprita
Jan 7, 2007
455
El Salvador
Your tps is out of adjustment, you problaly replaced it for another one but maybe the old tps was working properly you have to check calibration, its easy to test, just sit in the drivers seat with the ignition on and the diagnostig jumpered (make sure A/C is off) . Hit the gas, you should see code 51 release the peddle, and the code goes away. If it doesn't do that it needs to be calibrated. What brand of injectors are you using? dïd you flow test them? maybe 1, 2 are overflooding the cylinder, What are your a/r`s in your wideband? you could get it to idle and run with no load fine and have a decent a/r even if one injector is overflooding the cylinder, gasoline wich has not been sprayed properly doesn`t burn in the cylinder and the wideband can not read it.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
+1
This makes a big difference if the BOV is vented atmospherically,,,but then again he's running MAP, so its not like he's blowing metered air before it gets to the engine like the AFM would do. I mean, i run a atm vented HKS SSQV and don't have problems with stalling even with the Lex AFM, even when i had code 51 it was rare (had it for a long time too)
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
I had a RFL on my car a year or so ago and it would die like yours, I thought it was just cause I was venting to atmosphere so I went back to stock which fix the problem. Then a few months later a friend of mine game me a HKS SSQV knock off and I reluctantly put it on my car afraid it would do the same thing....but guess what it didn't. Nothing else at all had changed on my car between the BOV changes.
ITS YOUR RFL!!!! They are junk.....
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Folks, with the MAFT Pro and speed density setup, it CANNOT BE THE BOV. It's simply not possible. If the BOV is stuck open, the MAP sensor still reads the air correctly. If the BOV is stuck closed, the MAP sensor still reads the air correctly. I can remove the BOV and plug the hole, or for that matter leave it gaping open, and the car will still run just fine.
Running without one and the hole plugged might destroy the turbo, and if you left the hole unplugged your performance would certainly suffer, but the car will still run and drive fine.
Furthermore, there is no way that a BOV can cause a code 51.
supraman502
Apr 8, 2005
326
louisville, KY
there new precisions
the tps is set perfectly, how do you calibrate it though?
supraman502
Apr 8, 2005
326
louisville, KY
THANK YOU!!!
I've driven the car with an ic pipe hanging off, no boost, but the car still ran great lol
supraman502
Apr 8, 2005
326
louisville, KY
some extra info
The car ran/boosted flawless about 3 months ago, then I fried 3 piston rings.
Pulled the motor and put the probes in, dropped the motor back in and swapped out a 62-1 for the gt4088
