power window question
88mk3turbo
20
lynn mass
im stuck. both my windows wont go down. i tried 2 new switches,new window relay, i tested the motor and it worked fine, i tested the wiring and i do have power going to the switch. im wondering if its the circuit breaker? has anyone else had a problem with that. i also read on the forum that i could try to ground one of the wires. if so which one? any help would be really appreciated
88mk3turbo
20
lynn mass
that thread was very helpfull but i tested my switch on another mk3 and his windows went up and down fine. so im guessing that cancels out the possibility of my switch being bad. thanks alot
88mk3turbo
20
lynn mass
well i kept searching on these forums and saw a post about grounding the white with black stripe wire. i did that and it worked.window goes up and down but only my driver side. i am going to try my passenger side tommrow
