Power Voltage Stabilizer, is usefull?
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
If this usefull?
http://cgi.ebay.com/ebaymotors/Powe...tegoryZ33577QQihZ018QQitemZ280021365477QQrdZ1
Description:
The Power Voltage Stabilizer regulates the voltage of the car's electrical system, providing constant voltage at all times. Normally the electrical system's voltage will fluctuate under acceleration resulting in power loss and rough power delivery. The Power Voltage Stabilizer eliminates this voltage fluctuation, providing a constant voltage, thereby smoothing power delivery and optimizing power. Low rpm performance is improved noticeably, with improved response, acceleration, and smoothness. Fuel economy is also improved, especially for city driving conditions.
Smooth and stablize your idle
Improve all electrical component performance
Improve Audio Sound Quality
Improve Headlights Performance
Improve Spark Plugs / Ignition Performance
Improve Engine Response
Improve Fuel Economy
Optimize Your Battery Life
Decrease Engine Electric Noise
Quicker Engine Start Up
Smoother your acceleration
Easy Installation
Instruction Included
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
i had one of those back when i was NA..to tell you the truth they really dont do anything.. I put it on my car for 1 week (got it for free) and i felt no difference i didnt get better fuel economy my car didnt drive any smoother then it did befor and everything else mentioned that this product does really doesnt do any of em.To put it short the voltage satbilizer sucks! your better off buying a ebay mbc..half the price and more power...:icon_bigg
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
The only time I've seen those make any difference is when they're just acting as a band-aid for some worn out component (ie: bad ground lines, worn out alt which is producing a fluctuating output).
8,897
Yeah, it is useful. That is why the alternator has a built in regulator, and the battery is the size it is. The battery is a stabilizer.
Asterix
Lurker of Power
Vienna, VA
It is very pretty and will look pretty in your engine bay. Otherwise, it's a sham. It's hard to tell what's in it, but it looks like 5 capacitors. Whoo-de-doo.
Asterix
MKIIINA
Destroyer of Turbos
Plano, TX
Just get a grounding kit and replace all your old, corroded grounds across the engine. You may or may not see a difference but at least your electrical system will finially be grounded correctly.
Make sure you clean off the contact points also where you an connect also. a nice big brand new groud wire is pointless unless you have a good clean paint free place to anchor it!
SCC did a test on the grounding kits (not the stabilizer) and did see +5hp here and there but I'm willing to chalk that up to conditions and just simple variance.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I agree on getting a grounding kit also. Sand down the area that you are going to place you ground on (firewall for example). after bolting down the ground you may want to paint it to reduce chances of rust.
8,897
Chalk it up to dyno maniplutaion for a paying vendor, ala SF.
MKIIINA
Destroyer of Turbos
Plano, TX
meh iunno about manipulation. they did several runs and the highest gain was +5hp. there were +1-5 hp gains on all them but still thats not a big enough gain for me to use it as a performance mod. i would do it more for better grounds to replace my old ones, maintaince over power!
