power streering
zuf
manchester
lost of power streering
i have all the correct voltages from the speed sensors.
change the rack and pump by passed the oll cooler
tryed to bleed the the system as by the book still no power streering.
this is a 3ltr turbo 91 model with pps
radiod
1,342
Abbotsford, BC
I know this might sound stupid, but is the belt tight enough on the pump wheel?
That's what my first thoughts were too...
Do you know for sure that you're getting pressure from the pump?
Altezza576
268
New York
Check to see if you are getting air bubbles in your PS resevoir. When I changed my PS pump and steering rack on my MK4 it took a good week or two for the system to get back to normal with no bubbles and smooth steering.
make sure the PS resevoir doesnt fall below the minimum marker too, or you risk exposing the lower hose and sucking air into steering system.
Good Luck!
Altezza576
268
New York
bubbles = air in system. Make sure your PS level in reservoir is at the MAX. then proceed to start the car and turn steering slowly from one extreme lock to the next as decribed in the TSRM.
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
this will bleed the power steering? idk if i can turn it all the way while not moving.
