I bought the PS reservoir that beech perf makes because I didn't have one with my shell and swap. Just wondering how and where people installed it. I can't seem to think of any good ideas at the moment.
Thanks!
Thanks!
7M-KDL;1630944 said:between the headlights beside the hood latch(thats where mine is)
te72;1631442 said:Most any 1j power steering reservoir I've seen is kinda between the left side shock tower and the fuse box... kinda makes it a pain in the butt to change the oil unless you've relocated the filter though.
Dylan JZ;1631452 said:if one doesn't relocate, the K&N oil filter has a nut on the top allowing for much easier removal.
nctexan;1632194 said:So oppie are you using AN to barbed adapters on your Beech tank or just running AN lines?
Also wanted to ask if you knew off the top of your head the hose diameter that goes from pump to reservoir? Is it 5/8" or 1/2"?
fstlane88;1744878 said:If you have room, the easiest way would be a -8 an female to -10 an male adapter fitting on the bottom of the reservoir and then a -10 90* push lock fitting.
That type fitting will allow you to use virtually any rubber type hose from the bottom of the reservoir to the pump.
Links,
Adapter
http://www.racepartssolutions.com/proddetail.asp?prod=FRA4973
90* fitting
http://www.racepartssolutions.com/proddetail.asp?prod=FRA2090
HTH
